- Grounding in a FANUC Paint Robot
Proper grounding is a critical part of any paint robot installation, supporting both workplace safety and reliable system performance. In this video, we will go over the fundamental grounding requirements for a FANUC paint robot and explain why grounding plays such an important role in paint system operation.
The training begins with an overview of the two primary purposes of grounding. First, grounding helps support safe operation by reducing the risk of electrical shock and helping prevent conditions that could contribute to fires or other hazardous situations. Second, grounding helps protect sensitive electronic components by reducing electrical noise and improving signal integrity throughout the system.
We will also review the different grounding categories commonly found in a paint robot installation and discuss the purpose of each. The video introduces key grounding connections used with a purge-equipped controller cabinet and explains how earth ground, intrinsically safe (I.S.) ground, and power distribution ground work within the overall system architecture. Understanding the differences between these grounding paths is essential for maintaining compliance, reliability, and proper equipment performance.
In addition, we will examine grounding connection requirements and discuss how grounding points are integrated into the robot system. We will review examples of grounding locations, including connections within the controller cabinet and at the robot base, while highlighting important considerations for installation and verification.
Whether you are involved in installation, maintenance, troubleshooting, or system support, this training provides a practical introduction to the grounding concepts used in paint robot applications. By understanding the purpose and design of these grounding systems, you can build a stronger foundation for supporting safe and dependable robotic operations.
