Skip to main content
Nr0sljjjx3 1080p
Copying a Program to a User Frame
Share This Video
Facebook X LinkedIn Email
In this session, we will explore how to work with user frames and build on foundational concepts to copy an existing robot program into a new user frame. This walkthrough is designed to connect earlier lessons with a practical application that helps streamline programming across multiple fixtures. If you are looking to improve efficiency and consistency in your work cell setup, this overview will give you a clear sense of what to expect.
We begin by revisiting the role of user frames and how they relate to a fixture. We will go over how points are originally recorded relative to a specific frame and how shifting that frame affects program motion. From there, we move into a more advanced workflow where the same program is reused on a duplicated fixture by assigning it to a new user frame. This approach helps reduce the need for reprogramming and supports scalable operations.
Next, we will walk through setting up the work cell. This includes introducing a second fixture and teaching a new user frame that aligns with its position. We will cover how to activate the correct settings and properly record orientation and directional points. These steps ensure the new frame is accurately defined and ready for program execution.
Once the frame is established, we will go over how to calculate and assign the new user frame. From there, we move into the core process of copying the original program. We will show how to create a duplicate program, assign it to the new frame, and execute it to confirm that it follows the new fixture correctly.
Throughout the session, the goal is to reinforce practical skills while keeping the workflow clear and repeatable.
Requirements:
  • Basic understanding of user frames and coordinate systems
  • Familiarity with teaching points and recording positions
  • Access to a robot work cell with multiple fixtures
  • Existing program assigned to an initial user frame
What you will learn:
  • How to teach and define a new user frame for a second fixture
  • Steps for recording origin, X, and Y directions accurately
  • How to calculate and verify a user frame
  • The process for copying a program from one user frame to another
  • How to confirm proper execution of the duplicated program
By the end of this session, we will have a solid framework for reusing programs across multiple setups, helping improve efficiency and reduce programming time in real-world applications.
