- PalletTool 3 Custom Patterns
In this video, we’ll go over how to use FANUC’s PalletTool 3 software to quickly build custom palletizing patterns tailored to your specific needs. If you’ve ever found yourself scrolling through the automatically generated patterns and not quite finding the right fit, this walkthrough will show you how to take control and design your own layout with ease.
We’ll start by exploring the Edit Pattern feature, which gives you a visual interface to add, remove, and rearrange boxes on the pallet. You’ll see how intuitive it is to drag and drop boxes into place, with grid lines helping everything stay aligned. And if you need to turn off grid snapping for more flexibility, that’s just a click away.
What you’ll need:
- FANUC robot with PalletTool 3 installed
- Basic understanding of palletizing operations
- A pallet layout that requires customization
What we’ll go over:
- Using the Edit Pattern Screen
- How to add or remove boxes with drag-and-drop simplicity
- Working with different box orientations
- Enabling or disabling grid alignment
- Running a Custom Pattern
- How to save and apply your new layout
- Compatibility with flip layers, drop order, and approach direction
- Ensuring full access to all PalletTool 3 features with custom patterns
- Adjusting Box Spacing
- Setting gap spacing for box length and width
- Creating airflow paths or avoiding gripper interference
- Automatically aligning boxes with spacing intact
By the end of this video, you’ll be ready to create any palletizing pattern you need—whether it’s for operational efficiency, environmental requirements, or tooling constraints. The Edit Pattern feature makes it fast and simple to get started.
PalletTool 3 - Slip Sheets
