- How to use the Cut Chart Search Function
In this video, we will walk through how to effectively use the Cut Chart Search function, a powerful feature designed to streamline plasma arc cutting processes within the Hypertherm Equipment Library option R948. Whether you are working with newer software releases or looking to optimize existing workflows, we will guide you through the key steps and concepts needed to confidently apply this functionality in a production environment.
We will start by introducing the purpose of the Cut Chart Search tool and where it fits within the overall system. This feature is available in core software version V9.40P/83 or newer, and it provides access to recommended baseline parameters developed through extensive testing by Hypertherm. These parameters help establish process development starting points for cutting operations, reducing setup time and improving repeatability.
From there, we will go over how the selected process ID automatically populates Cut Schedule 1 with parameters. This allows operators and programmers to quickly apply baseline settings without manually entering each variable. Along the way, we will cover the practical steps required to locate, select, and apply these process IDs using the system interface.
You can expect a clear walkthrough of the navigation process, beginning from a cold start and moving through the Data and Type menus. We will also demonstrate how to define search criteria, execute a search, and confirm your selection so the schedule updates appropriately.
Requirements:
- Core software version V9.40P/83 or newer
- R948 Hypertherm Equipment Library option
- Access to Hypertherm Powermax Sync plasma cutting equipment
- Basic familiarity with system navigation and weld procedures
What we will cover and what you will learn:
- How the Cut Chart Search function supports plasma arc cutting applications
- Where to find and access the feature within the Cut Procedure
- How to input search criteria and execute a search
- How to select a process ID to populate Cut Schedule 1
- An overview of automatically populated parameters such as current, travel speed, cut height, pierce height, pierce delay, and kerf
By the end of this video, we will have a practical understanding of how to use the Cut Chart Search function to simplify setup and improve cutting performance. This overview is designed to help build confidence while encouraging deeper exploration of the system’s capabilities.
Overview of Adaptive Welding with a 3rd Party Sensor
