- iRPickTool Setup Overview
This video provides a practical overview of the iRPickTool setup process, designed for users who already have a working familiarity with FANUC iRPickTool concepts and terminology. We will go over the full setup workflow from start to finish, emphasizing the correct order of operations and highlighting how many steps build upon one another. Rather than diving into every configuration screen or button press, this session focuses on giving you a reliable roadmap that can help reduce rework, shorten commissioning time, and improve overall system stability.
Throughout the video, we will walk through a proven setup sequence for a simple iRPickTool line tracking application. We will discuss how early decisions affect downstream steps and why verifying data as you go is critical. You will also hear practical tips drawn from real world experience, including common mistakes that can lead to tracking errors, offset issues, or unexpected alarms. By following this structured approach, we can more easily troubleshoot the system if changes are required.
We will go over key setup areas such as robot and network configuration, RIPE ring considerations for multi-robot systems, encoder setup and verification, and teaching accurate reference frames. The video also covers sensor setup options, including vision based and non vision triggers, and explains how pick and drop reference positions tie back to the track frame. We will close with guidance on boundaries, perch positions, and best practices for safely testing the system before running at full speed.
Recommended background before watching
- Familiarity with iRPickTool terminology and basic line tracking concepts
- Experience navigating the FANUC teach pendant or using a teaching PC
What we will cover and what you will learn
- A logical and repeatable order for setting up an iRPickTool system
- How earlier setup steps affect tracking, picking, and dropping accuracy
- Practical checks to validate measurements and configuration data
- Tips to avoid common setup mistakes that cause rework or downtime
- How to approach testing and initial system validation with confidence
If you are responsible for commissioning, supporting, or optimizing an iRPickTool application, this overview can serve as a valuable reference before starting a new project or revisiting an existing one. By the end of the video, we will have walked through the full setup flow and given you a clearer picture of how the pieces fit together, helping you move forward with greater confidence and efficiency.
iRPickTool: Sensor Trigger Conditions and Actions
iRPickTool: RIPE Setup
