- iPC Introduction
FANUC iPC Box Introduction: Unlock Advanced Robotic Vision and Performance
In this video, we will go over the FANUC iPC Box and how it brings high-performance computing to advanced robotic applications. The iPC is an industrial-grade PC designed for tasks that demand exceptional processing power, seamless integration, and reliable connectivity. Whether you’re working with complex vision systems or optimizing automation workflows, this solution is built to deliver.
The FANUC iPC Box is equipped with multiple Gigabit Ethernet ports and a powerful CPU, enabling fast image acquisition and processing through iRVision software. Its compatibility with R-30iB+ and R-50iA controllers ensures smooth setup and commissioning, making it easier to implement advanced vision tools in your robotic systems.
Requirements for Setup:
- AC input power between 100–240 volts
- Ethernet connection to R-30iB+ or R-50iA controllers
- iPC Box is IP54 Rated
What You Will Learn in This Video:
- How to connect and configure the iPC Box for your system
- Steps to enable and name the iPC in Vision Config
- How iRVision runs on the iPC and starts automatically
- Using iRVision Manager for secure connections, backups, and vision process setup
- Best practices for integrating advanced vision tools like real-time tracking, bin picking, and AI-based box location
We will also explore how the iPC supports multiple camera types, including GigE 3DV cameras, CXV cameras with CCU, and Mech-Mind cameras for R-50iA controllers. By the end of this overview, you’ll understand how the FANUC iPC Box can enhance your automation capabilities with powerful vision applications and simplified integration.
iRVision Locator Tools
