- Python Programming on the R-50iA Controller
In this video, we will go over how Python programming can be leveraged on the FANUC R-50iA Controller to streamline automation tasks and enhance flexibility. Python script execution is a standard feature on this controller, enabling rapid development for file operations, communication processing, and numerical calculations. Whether you need to perform complex computations, manage production data, or integrate with external systems, Python provides a powerful toolset for your automation environment.
We will explore practical examples such as:
- Performing advanced calculations and storing results in registers
- Sending welding process data to a server after completion
- Monitoring production data and exporting it in CSV format
- Reading JSON motion path data to command robots using the Remote Motion Interface (RMI)
You will also learn about the supported Python libraries, including FANUC-provided packages for HMI device operations and remote motion control. Additionally, we will cover how to enable Python on the controller, execute scripts from the teach pendant, and manage multiple Python instances concurrently.
Requirements to Get Started:
- Access to the R-50iA or R-50iA Mate Controller
- Familiarity with teach pendant operations
- Basic understanding of Python scripting
What You Will Learn:
- How to enable Python on the controller
- Steps to execute and abort Python scripts from teach pendant programs
- Best practices for storing and managing script files
- How to pass command-line arguments and handle Python IDs
- Limitations of the Python feature and some supported use cases
By the end of this video, you will have a clear understanding of how Python can be integrated into your automation workflow, helping you achieve greater efficiency and customization.
