Skip to main content
Payload Estimation on CRX for Arc Welding
Apr 14, 2026
Skill Level: Beginner
Applications: Arc Welding
Share This Video
Facebook X LinkedIn Email
In this video, we will go over the essentials of payload estimation for FANUC CRX collaborative robots in arc welding applications. Accurate payload estimation is critical for ensuring smooth operation, reducing errors, and optimizing performance. This session is designed to help you understand the process step by step, so you can confidently apply these techniques in your own setup.
We will start by exploring how to determine armload and when armload additions are necessary. You’ll learn why factors like heavy dressouts or stiff weld cabling can impact payload accuracy and how to make adjustments to mitigate errors. From there, we’ll guide you through accessing the payload estimation menu on the CRX interface, so you know exactly where to find the tools you need.
Next, we’ll cover the four recommended positions for calculating payload. These positions serve as a baseline for accurate measurements, and we’ll explain how each one contributes to the overall estimation process. You’ll also learn how to set the schedule number and choose between known or unknown payload mass options, ensuring your configuration matches your application requirements.
Finally, we’ll discuss how to manipulate the dressout for the best results. Binding in the dressout can lead to poor measurements, so we’ll show you how to identify and correct these issues for optimal accuracy.
Requirements:
  • Access to a FANUC CRX robot
  • Familiarity with the robot’s interface and menus
  • Basic understanding of arc welding applications
What you will learn:
  • How to find and apply armload settings
  • When and why to add armload adjustments
  • Steps to access the payload estimation menu
  • The four key positions for accurate payload calculation
  • How to set schedule numbers and payload options
  • Techniques for optimizing dressout to avoid binding
By the end of this video, you’ll have a clear understanding of how to perform payload estimation on CRX robots, ensuring your system runs efficiently and accurately. Sign up now to watch and take your robotic welding process to the next level.
