Skip to main content
3h67w0o4kx 1080p
Torch Angle Adjustment using Simple Search
Aug 20, 2026
Skill Level: Beginner
Applications: Arc Welding
Share This Video
Facebook X LinkedIn Email
In this video, we will walk through how to use Simple Search to accurately set and maintain torch angle for arc welding within a FANUC environment. We will cover the fundamentals of how Simple Search functions in a practical application and how it can be used to improve weld consistency without requiring advanced touch sensing techniques. This session builds on foundational knowledge, so if we are already familiar with the basics of Simple Search, this will help connect those concepts to real welding scenarios.
We will go over how torch angle plays a critical role in weld quality, including its impact on penetration, joint strength, and overall appearance. By understanding how positional data is captured during each step of the Simple Search process, we can better control the welding outcome. The video explains how the first and second search positions work together to establish both directional and angular information, and how the starting point of the second search ultimately defines the remaining orientation of the torch.
Throughout the video, we will focus on practical setup guidance, including how to position the torch at specific work and travel angles during each search step. Rather than relying on complex programming or detailed touch schedules, we will highlight how Simple Search simplifies this process while still delivering reliable results. This makes it a valuable tool for improving repeatability and reducing setup time in arc welding applications.
By the end of this video, we will have a clearer understanding of how to consistently achieve the correct torch angle and why that precision is essential for producing high quality welds. This overview sets the stage for deeper learning while giving us actionable insight we can apply right away.
What You Will Learn:
  • How Simple Search is used to define torch position and angle
  • Why torch angle is critical to weld quality and consistency
  • The difference between first and second search positions
  • How positional data affects welding orientation
  • Practical setup steps for achieving the desired torch angle
Requirements:
  • Basic familiarity with FANUC robot operations
  • General understanding of arc welding concepts
  • Prior exposure to Simple Search fundamentals is helpful
  • Interest in improving weld quality and setup efficiency
