Skip to main content
Weld Equipment Setup using Weld EQ Setup Tool Option
Nov 17, 2025
Skill Level: Beginner
Applications: Arc Welding
Share This Video
Facebook X LinkedIn Email
In this video, Andrew Waite walks us through how to set up weld equipment using the Weld Equipment Setup Tool software option, also known as J708. Whether you're a system integrator or a technician working with FANUC robots and digital welders, this session will help you streamline your setup process and reduce reliance on analog interfaces.
We will go over how J708 simplifies the configuration of weld equipment that doesn’t have a dedicated library by using General Purpose arc welding modes. This tool is compatible with software versions 8.30P/17 and newer, and it supports digital communication protocols, eliminating the need for process I/O boards.
You’ll learn how to use an existing XML file, and we’ll guide you through the step-by-step process of loading and verifying the configuration. By the end of the video, you’ll have a clear understanding of how to complete a digital welder setup efficiently and accurately.
Requirements to Use the Weld Equipment Setup Tool:
  • Core software version 8.30P/17 or newer
  • J708 Weld Equipment Setup Tool software option
  • EthernetIP Scanner or DeviceNet Master option
What You’ll Learn:
  • An Overview of Weld Equipment Setup Tool Option
  • The main features of the Weld Equipment Setup Tool Option
  • How to configure digital welders using XML files
  • How to verify I/O mapping and communication status
This video is ideal for professionals looking to modernize their welding setup and reduce manual configuration time. Sign up to watch and take the next step in optimizing your welding operations.
