- Introduction to the Shape Generation 3 Option
In this video, we’ll walk through the fundamentals of the Shape Generation 3 option (R801), a powerful utility designed to streamline robotic programming for 2D feature cutting. Whether you're new to robotic programming or looking to optimize your workflow, this introduction will help you understand how Shape Gen 3 simplifies the process and enhances precision.
We’ll explore how this option reduces programming complexity by allowing users to define a single center point for each shape, eliminating the need for multiple taught positions. You’ll see how the shape cut interface supports a variety of customizable 2D shapes and how it integrates with TP program generation to save time and improve consistency.
Supported Shapes Include:
- Circle
- Hexagon
- Rectangle
- Slot
- Keyhole
- Pommel
- Custom
Requirements and Limitations:
- Only supports single-group motion
- Requires basic understanding of TP programming
What You’ll Learn:
- How to configure common shape parameters like:
- Start Axis
- Work Angles (X and Y)
- Blend-In and Blend-Off settings
- Cut direction and rotation
- Tool cut diameter and plunge/retract settings
- Specific shape details for each supported geometry, including:
- Diameter, speed, and radius settings
- Unique parameters for keyhole, pommel, and custom shapes
- How to use bevel angles and edge distances for advanced cuts
- How to select and apply custom programs for non-standard shapes
By the end of the video, you’ll have a clear understanding of how Shape Gen 3 can help you create efficient, accurate, and customizable cutting paths for a wide range of 2D features. If you're ready to take your robotic programming to the next level, this is a great place to start.
M-10 and M-20 Faceplate Interfaces
M-10iD & M-20iD Robot Library
