- ROBOGUIDE V10 Pick and Place
In this video, we’ll walk through how to build a simple pick and place simulation using FANUC’s ROBOGUIDE V10 software. Whether you're just getting started or looking to sharpen your simulation skills, this session will guide you through the essential steps to create a functional work cell and program a robot to pick up and place parts.
We’ll begin by creating a new work cell and configuring a robot using the Robot Creation Wizard. You’ll see how to select the robot’s software version, model, and application type to match your needs. Once the robot is loaded, we’ll add an end-of-arm tool using the image library.
From there, we’ll cover how to:
- Add parts and objects to the work cell
- Attach parts to the robot’s gripper and objects
- Copy and paste fixtures for efficient layout setup
- Enable the robot’s work envelope to ensure reachability
Once the environment is ready, we’ll dive into programming the simulation. You’ll learn how to create a simulation program, add pickup and drop-off instructions, and loop the process using labels and jump commands. We’ll also show how to enable profiler data collection so you can have accurate predictions of duty and reducer life for your robot.
Requirements:
- ROBOGUIDE V10 installed
- Basic understanding of robot simulation
What you’ll learn:
- How to configure a robot and work cell in ROBOGUIDE
- How to add and manipulate parts, tools, and fixtures
- How to build and run a looping pick and place simulation
By the end of the video, you’ll be ready to create your own pick and place simulations with confidence. Sign up to watch and see how easy it is to bring your automation ideas to life.
FANUC ROBOGUIDE Tutorial- Robot Setup, Fixture, Parts
