Skip to main content
C30mgvgx2k 1080p
Upside Down Robot Setup
Aug 11, 2026
Skill Level: Beginner
Share This Video
Facebook X LinkedIn Email
In this video, we will walk through how to invert a robot in ROBOGUIDE and explain why mounting orientation is an important part of building an efficient robotic cell. Adjusting how a robot is mounted can open up new layout possibilities, especially when working in tight or space-constrained environments. By configuring a robot to operate upside down, we can make better use of available space while maintaining performance and reliability.
We will begin by covering the fundamentals of why orientation matters. FANUC robots are built and tuned with gravity in mind, so when the mounting position changes, the robot must be updated to reflect that new orientation. Without proper configuration, performance and accuracy can be affected. This makes it essential to ensure the robot understands whether it is floor mounted, wall mounted, or inverted.
Next, we will go over how to access a controlled start, which is required to make these adjustments. We will review two different methods, one using the ROBOGUIDE interface and another through the teach pendant. This gives flexibility depending on how you prefer to work within your setup.
From there, we will step through the manual setup process at a high level. We will review key questions such as motion priority, mounting angle, axis range, and battery configuration. Each of these selections plays a role in ensuring the robot operates correctly in its inverted position.
Finally, we will apply the changes and highlight how the robot adapts once the configuration is complete.
What you will need before getting started:
  • Access to ROBOGUIDE with a robot cell
  • Basic familiarity with the teach pendant
  • Permissions to perform a controlled start
  • A clear understanding of the intended mounting position
What you will learn:
  • Why robot mounting orientation affects performance
  • How to enter a controlled start using two methods
  • Key setup options required for inversion
  • How to properly define an upside down mounting configuration
  • Important considerations for axis limits and maintenance settings
This overview is designed to help you quickly understand the process and feel confident applying it in your own projects.
