- iRCalibration Vision Multi-Cal Setup Recommendations
In this presentation, we will go over best practices for setting up IR Calibration Vision MultiCal. This session is designed to help you achieve accurate calibration results when working with multiple robots or robots and positioners. We will walk through hardware setup recommendations, software configuration steps, and the verification process to ensure your calibration is successful.
To start, we will cover hardware considerations such as camera and target placement. You will learn how to position the camera for optimal image quality, why background contrast matters, and how to secure components to prevent movement during calibration. We will also discuss posture settings that help avoid singularity errors and ensure smooth program execution.
Next, we will move into software setup. This includes defining coordinated pairs, selecting leader and follower groups, and creating calibration programs. We will address common issues such as vision failures, unreachable positions, and singularity errors, along with practical tips for troubleshooting and retraining images.
Finally, we will review how to verify calibration results and apply them correctly. You will see how to display results, update coordinated pairs, and complete the process with a power cycle.
Requirements
- Access to IR Calibration Vision MultiCal software
- Compatible camera and lens (e.g., Basler 20 with 12.5 mm lens)
- Robots and positioner configured for coordinated motion
- Secure mounting for camera and target
What You Will Learn
- How to set up hardware for accurate calibration
- Recommended camera and target positioning techniques
- Steps to configure coordinated pairs in Vision MultiCal
- How to create and execute calibration programs
- Troubleshooting common errors during calibration
- How to verify and apply calibration results
This overview provides the foundation for successful IR Calibration Vision MultiCal setup. By following these recommendations, you can streamline your calibration process and improve accuracy across your robotic systems.
iRVision Locator Tools
iRVision Notes Tool
