- New Naming Convention for R-50iA FANUC Robots
In this tech short, we’ll walk through the updated naming convention introduced with the R-50iA controller for FANUC robots. This new system is designed to make it easier to understand key robot specifications at a glance, while also supporting future scalability across FANUC’s growing lineup.
We’ll explore how the naming structure has evolved to include more meaningful identifiers, helping users quickly determine a robot’s payload, reach, mounting options, generation, and even its intended application. Whether you're configuring a new system or upgrading an existing one, this overview will help you navigate the changes with confidence.
The video also highlights how certain robot families are being reclassified under the new convention, streamlining the way we refer to models like the ArcMate, LR Mate, and DR series. You’ll see examples of how legacy names compare to the new format, and what to expect on updated robot nameplates.
In this video, we’ll go over:
- The structure of the new naming convention
- How to interpret payload, mount type, reach, and generation from the name
- Axis variants and application-specific modifiers
- Changes to existing robot family names
- Updates to robot nameplates and where to find detailed specs
You’ll learn:
- How to read and understand the new robot names
- Which models are affected by the naming updates
- What the changes mean for future robot identification and integration
- Where to locate key information on the robot itself
